UK - Teste - 128 kms com carga total
ruimegas
Gestor do Forum
Data de fabrico: 09 jun 2011
Mensagem por ruimegas » 04 abr 2011, 15:23
UK - Teste - 128 kms com carga total. (Test: 80 miles on a full charge)
"This test was to see how feasible it is to do an 80 mile trip in the Nissan Leaf on a full charge. The course was a circular route from Saltash, Cornwall and from there to Tavistock, Launceston, Bodmin and back to Saltash. This route is mostly fast A road but mostly quite twisty and being Devon and Cornwall it was almost never on the flat although there were no seriously long or steep hills. From Launceston to Bodmin however, there is a 20 mile section of dual-carriageway.
Journey started out at 96 miles estimated range. Temperature was 4 deg C. For the first 20 miles (to Launceston) the range meter and the state of charge bars were suggesting that this would be a very easy trip and at Launceston the distance travelled plus the estimated range was showing at 106 miles. There were just 40 miles to go and with 66 miles estimated and still 7 bars I was feeling very relaxed.
The driving style I adopted could only be described as extreme eco. I am very used to "hypermileing" as it is sometimes called... driving with the sole intention of extending range. This style of driving - uses acceleration only as much as absolutely necessary, uses considerable anticipation reducing the need to brake unless necessary, keeps speed down to 45-50 max (even on the dual-carriageways) and has no heating, a/c or radio. I am happy to drive in this way for a test such as this but it is very hard work and requires considerable concentration to do it well and so it isn't how I would drive normally.
So, from Launceston to Bodmin is 20 miles of dual-carriageway and so I settled down to 45mph when nothing was behind increasing to about 50 when there was to try to reduce the frustrations of the drivers behind. Even this relatively modest increase in speed had a significant affect on the state of charge and consequently the estimated range. Having joined the dual carriageway with 7 bars and an estimated range of 66 miles by the time I left it at Bodmin I was down to 4 bars and 35 miles. That 20 miles had brought my estimated range down to 95 miles. Still not looking too bad... 35 miles estimated with 20 miles to go but I was now feeling a little less comfortable especially as at times during the dual-carriageway leg the range had looked more like 80 miles.
Well I made it back to Saltash but not before the "Low Battery" warning flashed up at 14 estimated miles remaining and 2 bars.
Yes, 80 miles is clearly possible but I want to make a couple of things quite clear. Firstly, yes I did 80 miles on a full charge but there is no way that I would expect anyone to drive in this super "hypermileing" way all the time. Had I driven still carefully but more normally then I almost certainly would not have made it round. Secondly, doing any distance at all at 50 mph or more is going to hammer the range. I think I showed this a little in my 70 mile trip with heating. Range at 50 mph is going to be nearer 70 miles than 80 in my opinion and at speeds faster than that even less. Lastly, and this is perhaps the thing I will take most from this test, had I gone wrong, even just a little bit wrong, then I probably wouldn't have made it. Miss my turn-off the A30 and have to go another 3 or 4 miles to the next exit and then come back that 3-4 miles and that may well have meant that I didn't get around.
I want to leave you then with this thought... if you are in a Nissan Leaf and your journey mileage is within 20 miles of your safe range then you had better not get lost. Missing your exit or getting lost even a little, resulting in even a short diversion to get you back on track, could see you desperately searching for somewhere to plug in just a few miles from your intended destination... now wouldn't that be annoying. "
Em: http://www.leaftalk.co.uk/entry.php/16- ... ull-charge
batalha
Re: UK - Teste - 128 kms com carga total
Mensagem por batalha » 04 abr 2011, 18:46
Em breve, conto ver aqui um relato deste tipo mas com 140km (Oeiras>Évora) ;)
(ainda este mês) :roll:
ruimegas
Gestor do Forum
Mensagem por ruimegas » 04 abr 2011, 18:54
batalha Escreveu::| :| :|
Vamos usar os valores correctos 145 kms ;)
Mensagem por Filipe » 04 abr 2011, 20:13
AI AI como é que vai ser? :|
ruimegas
Gestor do Forum
Mensagem por ruimegas » 04 abr 2011, 20:18
Filipe Escreveu:AI AI como é que vai ser? :|
Tenho a impressão que nas primeiras vezes vou tomar o pequeno almoço à Expo e dou meia-hora a uma hora de "sumo" para descanso ;).
CarlosOliveira
Mensagem por CarlosOliveira » 04 abr 2011, 23:46
ruimegas Escreveu:
Ou então vais em modo tartaruga!!! :lol: :lol: :lol:
CarlosOliveira
Mensagem por CarlosOliveira » 04 abr 2011, 23:56
Penso que o que podemos retirar deste teste é mesmo que o LEAF se "sente" melhor na cidade do que em "open road", já que neste caso a recuperação de carga associada à travagem regenerativa será practicamente nula
Mensagem por mjr » 05 abr 2011, 09:59
O problema da "open road" são as velocidades médias mais elevadas. Esse é que é o grande papão (não , não é o FMI) da autonomia. Se em estrada aberta se fizer uma média de 70-80 km/h então a autonomia será igual ou melhor que em cidade.
ruimegas
Gestor do Forum
Mensagem por ruimegas » 05 abr 2011, 10:44
mjr Escreveu:O problema da "open road" são as velocidades médias mais elevadas. Esse é que é o grande papão (não , não é o FMI) da autonomia. Se em estrada aberta se fizer uma média de 70-80 km/h então a autonomia será igual ou melhor que em cidade.
:) Estou a contar com essas velocidades de 70 a 80 km/h para aumentar a autonomia :D . De qualquer forma primeiro vou ter de ganhar confiança e apurar o melhor ritmo de circulação para maximizar a autonomia e como tal as primeiras vezes, manda o bom senso, que "ateste um pouco na Expo até aferir as capacidades do Leaf em efectuar a viagem sem recarga nenhuma :D .
Mensagem por Filipe » 05 abr 2011, 10:54
Para mim o maior problema na estrada vai ser mesmo a implicação de manter uma velocidade ECO ( logo, bastante inferior á média do
trafego normal ), que leva a conflitos stressantes como já se está a verificar pelos reportes dos possuidores do Leaf nos States. ( Foi
por isso que tenho estado a pensar em colocar um aviso ( talvez em Leds ) para os condutores na minha retaguarda, que compreendam
que conduzir em Modo Eco não é para atrapalhar, mas sim uma opção mais Verde ( futebol á parte )).
