A Better Routeplanner (ABRP)
Re: A Better Routeplanner (ABRP)
Mensagem por migle » 17 set 2018, 15:33
Perguntamos (eu posso perguntar). Escolheste http ou https? É http.
Mensagem por migle » 17 set 2018, 16:41
Eu vou meter isto aqui no forum, porque pode haver mais quem queira ajudar, mas talvez seja mais rápido continuarmos por email.
Temos dados, mas precisamos de ter a velocidade do veículo, a potência instantânea ou tensão e corrente e a temperatura ambiente. Os dados que temos são assim:
{"Long": "-9.14111", "BatTemp": "28.5", "pass": "", "Elv": "91.08622888837593", "SOC": "72.58240000000001", "SOH": "96.14", "Amb": "86.0", "ChrgPwr": "0", "Wpr": "9", "Lat": "38.73981", "RPM": "-23", "PwrSw": "1", "PlugState": "0", "Gids": "265", "Tunits": "C", "AHr": "76.4122", "user": "email@email.email", "DevBat": "65", "ChrgMode": "0", "Seq": "49", "VIN": "SJNFA... ", "Odo": "15382", "Trip": "23"}
Perhaps he can help me out with what the parameters mean. Here's my guesses:
Long/Lat/Elv - GPS location
SOC / SOH - State of charge and state of health of the battery
Amb - Ambient Temp
ChrgPowr - ?? Possibly input power, possibly input power level?
Wpr = ???
RPM = RPM of the motor?
PwrSw = ?Car on off state?
PlugState = 1 when plugged in?
Gids = ???
Tunits = temp units? Why s ambient temp 86? seems like F
AHr = Battery capacity in Ahr
DevBat = ??
ChrgMode = ??
Seq = ??
VIN is self-explanatory
Odo = Odometer, probably matches Tunits (IE C = km, F = mi)
Trip = Trip counter?
The two parameters I really need are power (or voltage and current) and vehicle speed. I could make guesses based on lat/long and SoC, but it wouldn't be very accurate, and I'd need a lot more data points to get an accurate model. Is there an option to select more things to log?
It might be valuable to include him on this conversation
Há algum sítio no LS onde possamos seleccionar as coisas que queremos loggar?
Última edição por migle em 17 set 2018, 20:29, editado 1 vez no total.
Mensagem por Apr » 17 set 2018, 18:35
ChrgPowr - Pootencia de carregamento
Wpr = Estado do limpa para brisas
RPM = RPM do motor
PwrSw = botao de power do carro: 0- OFF ou ACC 1- ON 2-Ready to drive
PlugState = 0-desligado, 1-ligado, 2-em carga
Gids = GIDs
Tunits = graus C ou graus F
DevBat = nivel da bateria do telemovel
ChrgMode = nao me lembro bem acho que tem a ver se é AC ou DC charge
Seq = nao me lembro também acho que não é relevante e faz parte de mensagns de diagnostico
Trip = Trip index pode variar consoante o LS foi desligado corretamente depois de uma viagem
plpepapf
Data de fabrico: 01 out 2016
Capacidade bateria: 12 barras
Mensagem por plpepapf » 17 set 2018, 18:37
migle Escreveu:
17 set 2018, 16:41
Ecrã de definições do LeafSpy:
Mensagem por Apr » 17 set 2018, 18:45
Os dados vão todos de 1 vez em cada mensagem. Podem ser filtrados no servidor.
Mas em vez de estar a enviar assim os dados o LS também gera um ficheiro CSV com ainda mais dados. esses podem ser filtrados antes de ser enviados.
Esta funcionalidade de "server" é mais para gerar paginas em tempo real como dados de viagens.
Mensagem por migle » 17 set 2018, 20:27
Não há problema em enviar mais dados. Mas precisamos da potência, sem isso não dá, potência ou corrente mais tensão. Também a velocidade...
Como é que podemos arranjar isso?
PS: bem, rpm dará a velocidade.
plpepapf
Mensagem por plpepapf » 17 set 2018, 22:49
Hoje ao final da tarde voltou-me a dar erro de ligação.
Request timed out...
Não me estou a aperceber de fazer alguma diferente... será do lado do servidor?
Mensagem por migle » 17 set 2018, 23:10
Deve ser do lado do servidor. A mim também me deixou o Torque crashado (o Torque Pro é uma app de qualidade).
Mas o problema maior que temos agora é que se o log por http só tem esses dados, não serve. Ou vamos pelo CSV, que daria um bocado de trabalho a enviar, ou vamos pelo Torque também, seguindo as indicações que deu o BrunoAlves.
Apr Escreveu:
17 set 2018, 18:45
Aqui a intenção é estar a enviar dados em tempo real para simplificar o processo. Se for necessário fazer upload de ficheiros CSV manualmente, vai ser difícil ter algumas dezenas de pessoas a enviar dados e obter uma amostra estatisticamente relevante.
Alguém me pode arranjar uma amostra dos dados registados no dropbox? No caso do CSV, já encontrei informação e tem, de facto, tudo o que seria necessário (são 157 colunas?!). É curioso estar a fazer log para o servidor de coisas tão idiotas como o estado do limpa-para-brisas e não fazer da corrente e da tensão do pack.
plpepapf
Mensagem por plpepapf » 17 set 2018, 23:14
Será que se consegue que o programador do LS acrescente informação a esse log para o servidor?
Alguém já contactou com ele(s)?
Mensagem por migle » 17 set 2018, 23:33
Isto parece-me intencional, para limitar a utilização do LS Pro para outras aplicações. Quer-me parecer que o LS Pro não quer que se faça nada sem acordo €. Por que razão, escolhendo apenas 17 itens para pôr no log, haveriam de estar entre eles o estado do limpa-pára-brisas, o "modo de carregamento", e o SoC da bateria do telemóvel, e não tensão e corrente??
Isto está tudo no manual do LS Pro, páginas 39 e 40, por oposição ao CSV nas páginas 28 a 31.
Só há duas hipóteses: ou se consegue fazer upload do CSV automaticamente, ou temos de ir para o Torque Pro.
Voltar para “Off-Topic”
