Troca de pneus
OCasal
Troca de pneus
Mensagem por OCasal » 07 mar 2013, 17:03
Está a chegar a hora de trocar os pneus!
Quais aconselham?
preços? onde será mais barato?
ruimegas
Gestor do Forum
Data de fabrico: 09 jun 2011
Re: Troca de pneus
Mensagem por ruimegas » 07 mar 2013, 20:28
Renault And Michelin Create (Maybe) The Perfect Electric Vehicle Tire
Talvez ajude na escolha e já li noutro lado que não encontro que os Michelin estão no Top para os VE's neste momento
[IMG]http://insideevs.com/wp-content/uploads ... 50x307.jpg[/IMG]
Over-Enthusiastic French Execs Get Over-Enthused About Tires
"The Renault Zoe, which is coming to market very shortly in Europe, has a much greater range than that of its distant cousin, the (current gen) Nissan LEAF. Renault credits this “real world” driving range of up to 150 kms (93 miles) to three things :
a highly efficient regenerative braking system
a “clever” heat pump that minimises energy losses
the tires
It should be noted the Zoe has also been advertised with a homologated range of 210 kms (130 miles); a number that no one is likely to get in the real world.
At the forefront of the Zoe’s greater efficiency, Renault points to the tire. Tires account for “as much as 30%” of the energy consumed by an electric power train, so manufacturing a tire to reduce energy consumption is paramount.
“Jointly developed by Michelin and Renault specifically for ZOE, the Energy E-V tyres are possibly the most energy efficient tyres in the world, combining a low rolling resistance for a longer range at the same time as maintaining high levels of safety, especially when it comes to wet weather grip. The Energy E-V tyre is the result of a four-year development programme and is based on more than two decades of research into energy saving techniques.”
[IMG]http://insideevs.com/wp-content/uploads ... 00x166.jpg[/IMG]
New construction techniques, special compounds and a unique tread pattern mean grip in the wet or dry is exemplary, increasing road-holding and performance under braking and acceleration at the same time as reducing road noise.
We would also like to mention (and not noted by Renault) that the dimensions of the tire itself probably still play the largest factor in determining the range efficiency of the tire itself. ie) when you opt for the larger/fatter tires on the Model S, you get this disclaimer from the company – “21-inch wheels with low-profile performance tires reduce battery range compared to 19-inch wheels with all season tires”
To find out more, watch Renault’s Customer Specifications EV Director Bernard Dumondel take a ride in a Renault Zoe while talking to Vincent Rousset-Rouvière from Michelin.
[IMG]http://insideevs.com/wp-content/uploads ... 00x178.jpg[/IMG]
Em: http://insideevs.com/renault-and-michel ... icle-tire/
Re: Troca de pneus
Mensagem por mjr » 07 mar 2013, 22:54
Eu quando trocar, daqui a 20000km, ou coloco os Energy ou os Primacy Energy saver da Michelin.
aljesus
Proprietário Fluence
Re: Troca de pneus
Mensagem por aljesus » 08 mar 2013, 00:52
Quer isso dizer que não estão satisfeitos com os pneus de origem do Leaf?
Pela minha experiência diria que são muito superiores aos que equipam o meu Fluence e deverão ser a minha escolha quando tiver que trocar!
Os Ecopia custam perto de 80€.
Para mim a Michelin nunca teve pneus bons, não será agora que vou arriscar só porque fizeram parceria com a Renault!
Re: Troca de pneus
Mensagem por mjr » 08 mar 2013, 06:04
Nunca um pneu me durou tão pouco como os Ecopia. Normalmente faço perto de 100000km por pneu, com Michelin. Pelo que li, nos EUA a diferença de comportamento com os Michelin vs Ecopia é como da noite para o dia.
OCasal
Re: Troca de pneus
Mensagem por OCasal » 08 mar 2013, 15:20
Os pneus que falam neste vídeo já se encontram no mercado? Não constam no site da michelin!
Re: Troca de pneus
Mensagem por RJSC » 08 mar 2013, 16:05
Fizeram-nos só para o ZOE.
Assim que o ZOE se começar a vender, pelo menos a Renualt há-de os vender.
Mas estes pneus comercializados como "específicos para VE's" pagam-se bem...
Eu colocaria uns pneus de baixa resistência genéricos e quem raramente precisa da autonomia completa, uns normais.
Não consegui encontrar a diferença em percentagem de um pneu normal para um de baixa resistência nos sites dos fabricantes.
Uns dizem só que reduz sem darem números o que me deixa desconfiado, outros como a michelin dizem que pode poupar até 60L de combustível em 45000Km o que também não dá para concluir nada porque depende do consumo do carro que usaram para fazer os testes. :roll:
OCasal
Re: Troca de pneus
Mensagem por OCasal » 07 jun 2013, 00:31
Coloquei hoje 4 Michelin Energy Saver 205/55 R16 H91. Apos 200km comprovo que o carro ficou mt mais macio.
Re: Troca de pneus
Mensagem por RJSC » 07 jun 2013, 00:42
OCasal Escreveu:Coloquei hoje 4 Michelin Energy Saver 205/55 R16 H91. Apos 200km comprovo que o carro ficou mt mais macio.
Com mais macio queres dizer a rolar mais facilmente que com os originais?
Ou mais agarrado à estrada?
Re: Troca de pneus
Mensagem por Filipe » 07 jun 2013, 01:55
E já agora, quanto custaram os ditos. :?:
