MOOVE - Oeste
Re: MOOVE - Oeste
Mensagem por Filipe » 07 mai 2015, 01:47
x2 8-)
joelfmachado
Data de fabrico: 01 jun 2011
Capacidade bateria: 46,84 Ah
Re: MOOVE - Oeste
Mensagem por joelfmachado » 07 mai 2015, 10:53
Está aqui (mas foi ocultado pela REEV):
https://www.facebook.com/photo.php?fbid ... to_comment
pcdefl
Re: MOOVE - Oeste
Mensagem por pcdefl » 07 mai 2015, 11:20
joelfmachado Escreveu:Está aqui (mas foi ocultado pela REEV):
o que foi ocultado?
fui lá deixar o meu comentário; just in case, para o caso de o apagarem, mandei-lhe em mensagem pelo FB:
Dear Terry, you wrote:
"Dear Joel, my name is Terry and I am the project manager for Repute. These charge points are specifically for the Renault Twizzy's, which will be available free of charge for you or others to use. While waiting for the Twizzy to be delivered or returned, the charge point is locked. This is to make sure the parking space is available. The Twizzy can only be parked in tho space, no other vehicle, even if it is electric. I hope this makes sense."
I commented, sent here as a message in case you do not see the comment:
It does not make sense that a 16 Amps charging point, described as free and payed by public funds, remains locked with no car whatsoever using it, specially when the Portuguese charging structure is absolutely craving for charging points. Actually this is so absurd and shocking that the Portuguese Electric Vehicle community is appalled by the whole situation. You should try to use an electric vehicle in Portugal to feel what it is to pass by a locked charging point, publicized as free, and not being able to use it to charge a bit. Shame on you and your colleagues who, using public funds, do a very poor job promoting the EV agenda. Do you know what people, real needing people of EV mobility, are saying? They - meaning you - would do a better job not installing any charging point: as it is now this is an insult, a bad taste joke, a bad service. Hope you understand this reality and it makes sense to you. But if it did the locks would not be there, would they?
Regards,
Pedro Lopes
joelfmachado
Re: MOOVE - Oeste
Mensagem por joelfmachado » 07 mai 2015, 11:32
Ocultado da cronologia da página da REPUTE onde inicialmente estava
https://www.facebook.com/REPUTEeu?fref=ts
joelfmachado
Re: MOOVE - Oeste
Mensagem por joelfmachado » 07 mai 2015, 11:35
Para já reservei um Twizzy do projeto para dar umas voltas por Óbidos...
http://mobilidadeoeste.pt/index.php/reserva
Vamos ver no que vai dar...
Gostava que fizessem o mesmo para testar o tal "projeto piloto" que acaba em Junho...
pcdefl
Re: MOOVE - Oeste
Mensagem por pcdefl » 07 mai 2015, 11:46
joelfmachado Escreveu:Para já reservei um Twizzy do projeto para dar umas voltas por Óbidos...
vou fazer, comecei, mas aquilo é uma seca de preencher com tudo o que pedem!!
tenho que deixar para mais logo, mas vou mesmo fazer!! sempre quero ver no que dá aquela mobilidade gratuita a cadeado!!
pcdefl
Re: MOOVE - Oeste
Mensagem por pcdefl » 07 mai 2015, 11:48
joelfmachado Escreveu:Ocultado da cronologia da página da REPUTE onde inicialmente estava
por mim fiz:
deixei comentário na fotografia em que estão a jantar
acrescentei o meu comentário à resposta dele
mandei mensagem pelo FB ao dito senhor
se todos comentarmos o nosso descontentamento ao longo das entradas do FB deles, não têm como apagar/ocultar o descontentamento da comunidade, há quem ache que estão a fazer um
óptimo trabalho, só cada um de nós comentando pode mostrar como mobilidade gratuita a cadeado não é uma muito boa ideia
joelfmachado
Re: MOOVE - Oeste
Mensagem por joelfmachado » 17 mai 2015, 10:50
ontem passei no de Bombarral e lá estava o lugar com famoso cadeado e sem carro...
hoje tinha requisitado no portal um carro e nada... nem responderam...
tenho trocado e-mails com o financiador (Atlantic Area) e tenho-os esclarecido sobre o ponto da situação atual...
pcdefl
Re: MOOVE - Oeste
Mensagem por pcdefl » 17 mai 2015, 10:55
em Arruda cadeado, em Peniche cadeado, em Caldas cadeado, para não desigular dos outros locais a cadeado... e por baixo do cadeado o autocolante da zeev, boa publicidade digo eu
joelfmachado
Re: MOOVE - Oeste
Mensagem por joelfmachado » 17 mai 2015, 11:13
Entretanto já se pode consultar o regulamento (a 1 mês de acabar o "projeto")...
Que rico estudo cientifico devem retirar deste "projeto"... digno de tese de doutoramento... principalmente no método e na amostra...
http://mobilidadeoeste.pt/images/REPUTE ... steCIM.pdf
