e-NV200 Show Change of Policy on Battery Heating, Cooling?
Mensagem por VETL » 17 jun 2014, 09:30
Does Nissan e-NV200 Show Change of Policy on Battery Heating, Cooling?
Like humans, lithium-ion battery packs operate best in temperate climates, where it’s not too hot or too cold. Essentially, they like to be about the same temperature as us for peak energy efficiency, which is why many electric car manufacturers install liquid cooling and heating systems inside their cars’ battery packs to make it easy to heat or cool the pack as required to keep them healthy and happy.
[img]http://media.transportevolved.com/wp-co ... jpg?e0fa35[/img]
From the time its all-electric LEAF hatchback launched in 2010, Japanese automaker Nissan has maintained that it hasn’t needed to use any form of active liquid thermal management system for its battery packs, opting instead for passive forced-ventilation air cooling from driving the car along in hot weather and simple battery heating pads for extreme cold.
But at yesterday’s international launch event for the Nissan e-NV200 electric van — a vehicle which shares the same 24 kilowatt-hour lithium-ion battery pack and 80 kilowatt electric motor found in the Nissan LEAF — we noticed something rather interesting which makes us think Nissan might be rethinking its policy on battery heating and cooling.
The e-NV200, unlike the Nissan LEAF, has a small air conditioner built into its battery pack.
Plumbed in
Although Nissan mentions the fact the e-NV200 has an active battery cooling and heating system in its press release accompanying the e-NV200 launch, it wasn’t until we examined the battery pack more closely in a cut-away model on display that we understood how it worked.
Despite using the same capacity battery pack and identical battery cells to the LEAF, the e-NV200′s battery pack is more tightly packed together under the floor of the e-NV200 than it is in the LEAF.
As with the LEAF, cells are stacked, one on top of another, in an under-floor, sealed battery box — but at the front of the battery compartment just ahead of the first row of cells is a small radiator and large electric fan. And entering the battery pack from the front is a coolant feed from the van’s air conditioning system.
How it works
Nissan wouldn’t go into too many details with us, but it looks as if the e-NV200 can send warm or cold coolant from the van’s main HVAC system to the small integral radiator within the battery box. Air is then drawn through the radiator fins and is then cooled or heated as needed to keep the battery pack and battery box at optimum temperature.
It’s important to note here that unlike some battery packs with liquid thermal battery management, the e-NV200 doesn’t have pipes running in between inside the battery pack. Since the battery itself is sealed in one large battery box, the radiator at the front serves a similar function to the heater matrix inside the van’s cabin: keep everything inside that closed space at a pre-determined, set temperature.
Why is it needed?
Nissan says the addition of the internal radiator is to keep the battery pack’s temperature at optimum operating conditions, since the more tightly-packed battery pack of the e-NV200 has less space for air to circulate around the cells and therefore is more prone to changes in heat than the LEAF battery pack.
There’s also some allusion from Nissan that it expects the e-NV200 to be treated far more roughly than any of its LEAFs would be. As well as the obvious misuse from the hands of delivery drivers or high-milage fleet life, Nissan engineers told us they wanted the e-NV200 to cope with frequent rapid charges in a single day without damaging battery life.
But there’s also the simple fact that with its much larger surface area, heavier weight and 770 kg cargo capabilities, the e-NV200 can’t travel as far per kilowatt-hour as the LEAF. Although NEDC range is set at 170 kilometers, our expectation is a real-world achievable range of 60-70 miles when empty and perhaps less when fully laden. In that situation, the battery packs need to be at optimum temperature to give the best possible range.
What about the LEAF?
When it came to market in late 2010, many criticised Nissan’s all-electric LEAF electric hatchback for not having any form of active battery cooling or heating system fitted as standard. Unlike cars like the contemporaneous Mini E, Tesla Roadster and Chevrolet Volt — all of which used active liquid thermal management to keep their battery packs operating at optimum temperature — the Nissan LEAF simply came with passive, forced-air ventilation.
At the time and even today, Nissan maintains that the LEAF’s battery pack doesn’t need any form of active cooling or heating system to keep its battery pack healthy. To date the only concession Nissan has made to LEAF battery temperatures is to include a cold weather package with simple heating elements to keep the battery pack above -15 degrees Celsius in cold weather environments.
For LEAF owners in ultra-hot climates like Arizona however, a lack of battery cooling in the LEAF has lead to some pretty shocking premature ageing, rapidly decreasing battery pack capacity due to prolonged 50+ degree Celsius temperatures. And while all Nissan electric vehicles come with a battery warranty that covers the effects of premature battery ageing due to extreme heat, Nissan’s experiences in Arizona has led it to develop a more temperature-resistant battery chemistry, a chemistry which Nissan is readying for production later this year.
No one we spoke to at Nissan would confirm or deny the possibility that Nissan is considering active battery cooling or heating for future electric vehicles, nor could we get any indication of the feature making its way into the next generation LEAF, a car we’re expecting to debut some time in 2016/17.
But after seeing first hand how our own LEAF’s battery packs like to heat up in hot weather when rapid charging — not to mention seeing how little the e-NV200 vans appeared bothered about the hot Spanish sun yesterday — we can’t help but think Nissan is about to make a u-turn on its battery cooling policy.
We’re not engineers of course — nor can we tell for sure — but given how alike the LEAF and e-NV200 are, we think it’s highly probable.
Fonte: http://transportevolved.com/2014/06/12/ ... g-cooling/
Vejam também os comentários.
Re: e-NV200 Show Change of Policy on Battery Heating, Coolin
Mensagem por mjr » 17 jun 2014, 09:42
Um design simples e eficiente. Não tão simples quanto o do iMiEV, mas certamente mais eficiente pois o radiador está colocado dentro do pack. Esperemos que a próxima versão do Leaf tenha algo semelhante, o incremento de custo não será significativo, ao contrário de um sistema de climatização do pack com líquido.
Mensagem por VETL » 17 jun 2014, 09:46
mjr Escreveu:Um design simples e eficiente. Não tão simples quanto o do iMiEV, mas certamente mais eficiente pois o radiador está colocado dentro do pack. Esperemos que a próxima versão do Leaf tenha algo semelhante, o incremento de custo não será significativo, ao contrário de um sistema de climatização do pack com líquido.
Sim, eficiência acima de tudo.
Mantém o pack vedado e apenas climatiza esse compartimento...
A enveredar por um sistema destes também para os Leaf's, é um grande passo atrás... Mas bem dado e na direcção adequada.
Mensagem por mjr » 17 jun 2014, 10:20
Claro que o ideal seria uma química resistente a temperaturas elevadas... mas como solução de compromisso parece interessante esta solução.
Mensagem por VETL » 17 jun 2014, 10:40
mjr Escreveu:Claro que o ideal seria uma química resistente a temperaturas elevadas... mas como solução de compromisso parece interessante esta solução.
Sim, é verdade...
Mas essas coisas demoram normalmente mais tempo e não dependem só da Nissan.
Depois das evidências de que a Nissan estava bem informada quanto ao efeito das temperaturas nas baterias (baterias novas no Arizona, aumento da garantia nos países frios, etc...), acho ridículo terem continuado a insistir que o pack não necessitava de climatização...
Mensagem por RJSC » 17 jun 2014, 10:46
E como de costume na indústria, quem comprou (e continua a comprar no momento) os Leafs "que se lixe" e só faça cargas rápidas no inverno e ande pela sombra se quiser ter bateria para uns anos decentes.
Isto nos leafs atuais resolvia-se com uma válvula extra no sistema de A/C, 2 derivações e software novo (além de um pack novo com o radiador lá dentro).
Mas a vontade é nula...
Já estão vendidos, não interessam.
Devia pelo menos ser opção extra para quem troca o pack na garantia ou comprar um novo.
cromero
Data de fabrico: 09 mai 2014
Mensagem por cromero » 17 jun 2014, 11:04
RJSC Escreveu:E como de costume na indústria, quem comprou (e continua a comprar no momento) os Leafs "que se lixe" e só faça cargas rápidas no inverno e ande pela sombra se quiser ter bateria para uns anos decentes.
Como comprador muito recente (2 de Junho) de um LEAF novo, sinto-me um pouco indisposto ao ler estas coisas. Se tivesse frequentado este Fórum com uns dois ou três meses de antecedência relativamente à data de compra, talvez a Nissan Portugal tivesse, nesta altura, menos uma unidade vendida. Mas há um aspecto em que eu não quero acreditar: a Nissan não pode marimbar-se para quem já comprou os seus carros eléctricos. Porque não há anti-propaganda mais demolidora do que a que é feita por clientes insatisfeitos. Ora, como me parece óbvio que a Nissan quer continuar a ser uma das marcas com implantação maior nos eléctricos, borrifar-se para os clientes que já lhe deram a confiança seria um tiro no pé, ou, mais do que isso, uma bazucada! Francamente, não me parece que os japónios sejam assim tão burros. Não acredito.
Mensagem por RJSC » 17 jun 2014, 11:34
Mas marimba-se!
Nos EUA até houve um processo conjunto em tribunal e foi por isso que apareceu a garantia de capacidade de 70% também para os modelos de 1ª geração já vendidos.
Podiam no mínimo colocar nos Leafs de 2012 a carga da bateria em percentagem no painel de instrumentos e não puseram na última atualização de software que mandaram fazer. Era só mais software, não implicava qualquer alteração e mesmo assim nada.
Também falaram vagamente em um upgrade de carregador para 6.6 kW para os modelos de 2012 mas depois negaram-se e tiveram que ser terceiros nos EUA a colocar carregadores mais potentes nos de 2012.
A indústria automóvel clássica odeia a ideia de upgrades aos modelos já vendidos porque diminui a motivação para as pessoas comprarem um novo.
Basta ver como acabaram por exemplo com as gavetas para auto-rádios: agora vem tudo integrado nos plásticos e quem quiser um rádio novo que leia novos formatos multimédia ou um rádio com aplicações instaláveis, tem que comprar um carro novo.
A gaveta DIN dupla que existia suportava perfeitamente um ecrã multimédia, mas a vontade foi obviamente fazer os modelos mais antigos o menos atualizáveis possível.
Mas todas as marcas clássicas são assim.
Só a Telsa oferece upgrades aos carros já vendidos (como o escudo de titânio para o fundo da bateria) ou troca de carregador para a versão de 22kW (embora cobre quase o dobro do preço que se vier de série pois dizem que tem que voltar à linha de montagem).
At Tesla's sunny headquarters in Palo Alto, Calif., I asked CTO JB Straubel when to expect the next model upgrade for the Model S . He quickly dismissed the automaker cliche of updates based on model years, saying that Tesla would release new features for the Model S as his team finished creating them.
http://www.cnet.com/news/teslas-path-to ... dable-car/
cromero
Mensagem por cromero » 17 jun 2014, 11:57
RJSC Escreveu: A indústria automóvel clássica odeia a ideia de upgrades aos modelos já vendidos porque diminui a motivação para as pessoas comprarem um novo.
A perspectiva é bastante assustadora. Mas eu insisto nisto - não sei o que é melhor para os fabricantes: impedirem upgrades para motivarem a compra de carros novos, ou apostarem na satisfação dos clientes para garantirem boa publicidade e melhores vendas futuras. Num segmento de negócio como o dos eléctricos, praticamente virgem e com a particularidade de atrair, pelo menos nesta fase, clientes muito mais atentos e sensíveis a questões técnicas, eu creio que a satisfação dos clientes é crucial. Mas não seria a última vez que o disparate ultrapassa o bom senso. Veremos
Malm
Proprietário i-MiEV
Data de fabrico: 31 mar 2011
Mensagem por Malm » 17 jun 2014, 13:59
Nem sei que dizer. É a primeira vez que isto acontece, um modelo é ótimo na Noruega, o mesmo carro tem um grande defeito em Portugal. Os elétricos tem de estar adaptados ao clima onde vão ser utilizados. A Nissan falhou nesse aspeto. A Mitsubishi, com o i-MiEV, esteve um pouco melhor, mas por si só também ficou aquém.
